Old 08-23-2012, 12:46 PM
Flatbedford's Avatar
Default PTO bearing and collar
I removed the PTO from my 149 in order to adjust it and replace the bearing. I used a three jaw puller to remove the bearing, but I can't get the set screw on the collar to budge. The replacement bearing comes with a new collar, but can I just leave the old one and install the new bearing?
Steve,
Former multiple 149 owner.
Old 08-23-2012, 04:56 PM
TommyK's Avatar
TommyK TommyK is offline
Steve, did you loosen the set screw on the locking collar and tap the collar to unlock the bearing before you pulled the bearing off with the gear puller? If you pulled the bearing off without unlocking the collar I wouldn't reuse that collar. You need to loosen that set screw even if you reuse the collar, to be able to lock the new bearing on. If you did unlock the collar before using the puller, and the collar looks like it's in good shape, then you could reuse it.
Old 08-23-2012, 04:59 PM
You need to remove the old collar. You're not going to be able to get the new bearing tight with the old collar there.
Old 08-23-2012, 05:18 PM
I see. There is only so much force that I can put on the set screw with 1/8" allen key. I left it soaking in Kroil last night. We'll see later.
Steve,
Old 08-24-2012, 08:43 AM
bigdaddyjak bigdaddyjak is offline
Put a little heat to it
To much to list!
Old 08-24-2012, 10:37 AM
I took a closer look last night and realized that I had to loosen the lock nut for anything to happen. Once I got a wrench on it, it can apart easily. The new collar came with only a short set screw and no lock not. Should I use the old, longer set screw and lock nut on the new collar, or just go with the new set screw?
Steve,
Old 08-24-2012, 11:37 AM
TommyK's Avatar
I have just a set screw in my locking collar, and I haven't had any issues. The locking collar I replaced had a longer set screw and locking nut, it was not reusable after I took it off. That's how they were installed originally, it's mentioned in the service manual.
Old 08-24-2024, 07:52 PM
CubbyLover2021 CubbyLover2021 is offline
My bearing has some wobble in it as well.
I have a 1973 149. What parts do I need I order to fix the wobble? Here's what I've found so far...
Anything else I would need?
Old 08-24-2024, 11:41 PM
I think you would have a lot better chance of getting some help
with your project if you start a thread. This one is quite old.
There is a load of info in the archives here that will help you with
pictures and descriptions.
There is also a manual in the library that shows the whole setup you
are working on.
Work through the parts website with link at the top of the page
Also links to sponsers who will have all the parts.
Pics are always a good thing to help us.
Ken
