Old 03-29-2021, 09:26 AM
FLETCH14519 FLETCH14519 is offline
Default 1450 Metal Color in Oil
The other day when I changed my oil, I found the oil had a metal tint to it when I cleaned the dip stick off with a Paper towel. The engine does make a weird rattle noise when mid to high idle. So I was gonna pull the engine and send it off to get rebuilt by my friend that works on small engines. Is there anything we should keep an eye on while it’s out?
Old 03-29-2021, 01:15 PM
mortten mortten is offline
ISO mounts. Cradle modification. Squeezing the front axle channel back to spec. Check the oil pan for stripped bolt holes and uneven wear.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 03-29-2021, 02:46 PM
When the engine is apart, do check the condition of the balance gears if equipped.
Most remove them, but they can be kept if they are in great shape or the bearing/shafts are renewed.
Most are worn and a ticking time bomb.
