Need some help with a sleeve hitch
Planning on making my own sleeve hitch just need some dimensions how long is the over all length an how long does the pin need to stick out of the top part of the 3 point planning on making one like this thanks for any help
http://www.onlycubcadets.net/forum/a...1&d=1421466755 |
You can make this whatever you want. The overall front to back is typically 10".
That's a Brinly adapter.......
Well I still have to make my lift straps but got the biggest part done
Welded some chain to a 1 inch pin since I dont have the lifting straps to try out the home made share I made it worked pretty good
Looks good, if you bend that something else broke too...
1977 1650 with cast iron lower grill housing, cast iron oil pan, 54" push-snow blade, rear blade, disc-harrow, 44c and 48" decks, Two cultivators, #1 tiller with both extensions, loaded tires, 75' weights and chains, #2 cart. |
That looks great! Member Jeff in PA also makes some nice ones (bought one from him) pretty good satisfaction in making one yourself though, nice work
-Rick IH 782 IH 126 CCC 1863 |
Jeff |
