Alcohol tank
I'm redoing a cub stock altered puller and I want to use an aluminum tank. The question I have, is should I use a vented tank or a non vented tank?
I'd run a vented tank and just put in enough alcohol for the day your pulling, I don't think you want it sitting with a full tank. When I was younger I ran Jr dragster and we had 2 tanks, one with alcohol and the other with gas so when I was done with my run I'd switch it over to gas to get all the alcohol out of the carb because it will eat the carb gaskets.
I'd agree on the vented tank, we used to fill the tanks then pump them dry after the pull.
Thanks guys ive never delt with alcohol before so its all gonna be new.i need to learn the whole fuel system.i have always been in the cam2 and turbo blue world.
