Old 08-05-2013, 01:36 PM
Pa Cooner's Avatar
Pa Cooner Pa Cooner is offline
Default Lawn roller
This winter I had some spare time on a blizzard of a saturday and I had this old 40 gal hot water tank laying around. Tell me what you think, I only have $20 invested in some welding wire!
Old 08-05-2013, 02:18 PM
It looks great! You did a good job!
Old 08-05-2013, 03:13 PM
Pa Cooner's Avatar
Here is another shot of it from the front
Old 08-05-2013, 05:57 PM
Looks good!
Old 08-05-2013, 11:18 PM
Looks sweet! Nice work.
I filled mine with concrete. It works great.
Old 08-06-2013, 01:40 AM
very nice!
Old 08-06-2013, 04:51 PM
Pa Cooner's Avatar
It has about 35 gals of used motor oil in it and rough guess its somewhere the 350 to 400lb range.
Old 08-06-2013, 11:43 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
What did you do for an axle? Does it have bearings? That is a great idea I have access to old 75 gallon water heaters at work. I will prob do this as well.
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 08-07-2013, 09:31 AM
Pa Cooner's Avatar
I used a pair of late 90's dodge stratus front wheel hub and bearing assemblies for bearings and the ends off of the front drive axle shafts. I welded the cv axle ends to the tank and then made the frame so that it bolted to the bearing units. This way if I need to replace a bearing, I just unbolt the frame and slide the bearing off.
Old 08-07-2013, 12:56 PM
Berwil's Avatar
Berwil Berwil is offline
Is that cross bar the front bumper from the same stratus? haha
Job well done!
