Points Gap Question
I know that a place to start with points is .020 or a match book cover. Question is - what are the extreme max and minimum gaps you've had to live with a Kohler engine to get your IHCC's engine timed and running correctly?
Thanks! Bill
IH Cub Cadet 109 IH Cub Cadet 126 (2) IH Cub Cadet 149 IH Cub Cadet 1650 MTD Cub Cadet LTX1042 |
I've heard anywhere from .016 to .022 is somewhat common. Beyond that, I'm sure we'll be seeing some extreme numbers pop up pretty soon.
-Ryan
Use the static timing method. Do worry about the gap. The big thing to worry about is when they open.
Agreed!
our alky motors can run anywhere from 27-35. a gas stocker starts to detonate between 25-26 degrees of timing.
Is there a link on how to static time a kohler? Have found much on youtube.
The tech library is a wonderful thing.
Will this system work with a KT17 series II? I'm having a real hard time with it. Doesn't wanna start, backfiring through carb and muffler and runs real rough.
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169. Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3. |
as long as it has points. yep. even a small block chevy .
Also agreed. Point gap really is not that important. On a Kohler it's all about timing. According to the mark on the flywheel it is 20* BTDC. I would probably err on the side of too much advance. They tend to run better that way. 22* - 24* is nice if you don't have too much kickback when cranking (which is the drawback of higher advance)
Matthew B 1972 129 w/hydraulic lift and head light option soon to be repainted |
