Powder coating question(s)
I did a search on powder coating on this site and it was very helpful. One questions I have that I couldn't find was this:
Does anyone know how many pounds of powder it takes to paint the frame, axle, fenders, etc that is Yellow. I think I may try to powder coat some spare parts and If the results are good, I may do a a whole wide frame in powder. I don't want to buy too much or too little so if someone has experience, it would be greatly appreciated. Bob
Cub Original,100, 102, 104, 126, 147, 1450 times 2, 1650, 800 and 169 times 2 1a & 2 IH tillers, #1, 2 & 4 carts, snow blade, Johnson Workhorse model 10 loader, Brinly 10" plow, multiple decks, etc. |
The guy who is doin mine told me to order 4 lbs. yellow and 1 of white. About $130 for the powder From' Columbia Coating. The stuff I am getting is metal flake, regular may be a bit less because they can buy it in larger quantities. The engine hAS TO BE DONE IN PAINT, NOT POWDER.
CC 126; CC 122; CC1450; Brinley plow; Brinley cultivators, CC front blade; IH 48" peg tooth harrow. & 1320 Ford New Holland(EEK!!!) |
Bob, the cost of the powder is cheap $2 for standard blend and up to $7 for a custom mix (that's per pound and the more you buy the cheaper it gets). With powder coating it's all about the labor if your taking it into a shop. Are you doing this at home or taking it to a shop?
I got lucky my local powder coater has the correct colors for the originals I'm doing. The white was a stanard color they carry. With powder coat you can blend in how much of a shine you want it to have. Be ready to tear everything apart for powder coating. All seals, gaskets, o-rings and your transmission. It's a 100% tear down no way to do it with out doing it. |
Are you doing this at a powder coating shop or home? |
Powder Coating
What are the steps I need to take to get my 128 ready to powdercoat. I have totally disassembled it except for the tranmission. What do I do to the trans?
It has to come apart too! All rubber seals and gaskets.
1782 smoker!!, 169 and parts 128 And a bunch of stuff that fits on the back of them LOL |
Powder
I'm powder coating my 149 and think 3 lbs yellow will be more than enough.
*the two colors I am using are from prismatic powders (541) 826-1422. *They are porcelain white (pss 2094) and tractor II yellow (pss 1836). I think they are very close to original for my 149 and were a lot cheaper than $32 per lb. |
