Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 08-25-2013, 12:21 PM
rmunro's Avatar
rmunro rmunro is offline
Default Repower
I am thinking of taking a look at the following Magnum to replace the K series in either my 1450 or 1210.
I think the price is far too steep, although is complete with carb, starter etc.
Any help appreciated.
http://toronto.kijiji.ca/c-buy-and-s...AdIdZ514654634
Model M16S Spec- 711527 Serial 2007808863
Also how can year of manufacture be determined??
Roger,,109,1450,1210
Some Days all You Can Do Is Hang On!!!
Old 08-25-2013, 12:25 PM
Inactive Member
That engine was designed and built for "Broward Equipment" for some mower application.
Old 08-25-2013, 02:23 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
has a 1 1/8 crank so you need to find a PTO to fit it, its 4 in long so you have to shorten it then drill the taped hole deeper and thread it. and its probably a wide base block that won't fit in a cub without some major mods
Old 08-25-2013, 08:17 PM
rmunro's Avatar
K, thanks guys. Too much work.
Old 08-25-2013, 11:10 PM
1-1/8" PTOs are very common no big deal. The long shaft is also no big deal just put a spacer on the end of the shaft after you put the PTO on.
Old 08-26-2013, 11:19 AM
rmunro's Avatar
Thanks Sam. But still have the difference in the block to deal with. I don't want to modify the tractors too much, but if I do will go for a twin cylinder then. He wants too much anyway--at that price I could rebuild both of my engines.
