Chevy points conversion?
When converting a K-series to Chevy points, do you use the Kohler condenser or the Delco Remy condenser? Thank you for your time.
Don B, USAF 1962-1968, Ft. Wayne, IN |
You can use either one. I run 2 condensors on mine and have used both with no issues.
In my opinion unless you are turning major RPM it is not worth converting to Chevy points.
and then you might as well put the crank trigger on and be done with point
Agreed. Crank trigger was the best money I have ever spent on a pulling tractor.
I did not ask for your opinion on RPM's. I asked about condensers.
Does either condenser have and atvantage over the other? This engine is a K 321 and will be set to turn 4000 r's.
and RPM's would make a difference on what I think of condenser's . |
If your hell bent on using Chevy points I have three brackets and three sets of Chevy points I'll sell you. As Don has said there are no gains to be made.
