Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 06-13-2020, 09:04 PM
V30crewcab V30crewcab is offline
Default 1440 leaking oil
my friend bought a 1440 from me a few years ago, been mowing with it no problems. it started leaking oil last year. replaced oil pressure switch, and it was good for awhile. then it started pouring again that the end of the summer.
took it off, cleaned it up, and put new seals on both sides (pto and flywheel) of the thing. he mowed one time and when he shut it down it puked oil out again. looks like it may be coming from the top of the motor, but can't see from where for sure. fins are all clean. would the pvc baffle up top overflow maybe? there was a little oil in the air cleaner housing.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 06-14-2020, 03:16 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
Maybe the dip stick tube grommet. I had to replace the one in my 1641.
Cannon
Old 06-14-2020, 06:41 AM
cooperino's Avatar
If it is coming from the top.. Valve cover gasket, breather tube.. Yes a clogged breather could cause a leak to happen. Usually that would cause a seal to leak over a gasket. I would pull the engine, Clean it up, Run it on the bench.
Old 06-14-2020, 07:06 AM
Inactive Member
I would second that.
Old 06-14-2020, 10:44 PM
it was pulled and pressure washed when we did the seals, so its still pretty clean other than the fresh oil. didn't look like the dipstick tube seal was leaking. I am going to pull the breather setup and look at that. thanks.
72 scout
IH 404 tractor
