bolts
Hello, What size bolts do you use to bolt a ring gear to a two piece carrier? I'm thinking 5/16x1 or 11/4 fine thread with steel lock nuts. I did one 3 years ago and have forgotten, i need to get a couple sets. Thanks Mike
I used 5/16 x 1 1/2" I think. Grade 8 fine thread bolts. I then cut off what stuck through the nut and welded the nut to the bolt.
OK I gotta ask, why would you weld the nut to the bolt? Red Loc-Tite is more than enough.
Because the way I see it. If I ever had to take them off I would be replace them anyway. And this way I know there is no chance of one coming out. Cheap insurance IMO.
Sure hope you are just messing up the threads a bit with the welder.
Because if you are getting them hot, the bolt becomes brittle, and streaches. thread locker is more than enough with no drawbacks. |
I smack um with a hammer and chisel to lock the nut to the bolt threads. and lots of loctite
Doug Original / IH 70 / IH 149 / IH 1650 / IH 582 / CCC 1772 West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
bolts
Bump,how about a correct length anybody. Where's Don V when you need him.
5/16 fine thread grade 8 , 1 inch long with lock nuts and a dab of locktite. I use those same bolts for a fine spline or a dart setup. if you can find them in a allen head it makes installation a little easier since its difficult to tighten or hold the nut or bolt on the ring gear side. I had ground down a socket for clearance since there are so many running around with hex bolts in them
bolts
Thanks Don, i've been to a few NQS pulls in our state over the years that i knew you were there. Wanted to meet you but never made the connection. I live real close to Mr.N and he's helped me out on a couple. He gave me the bolts for the first one. I've bought gears,shafts and things off him. Thanks again, Mike
