Old 02-18-2013, 07:52 PM
Plowboy1086's Avatar
Plowboy1086 Plowboy1086 is offline
Wink cub cadet 482 from MD
Whats up guys
I just joined. I have a Cub Cadet 482. I'm building into a puller. Any tips?
:IH logo
Old 02-19-2013, 12:31 PM
Pigpuller Pigpuller is offline
Default check book
just make sure you have a big check book and be ready to use it if you want to be competative . i just got the new midwest super cub catalog i see for a set of rear wheels they are up to 270 dollars. that is just crazy.the sad part is no matter what you are looking to buy you might as well buy it today because tomorow it will cost more.
Old 02-19-2013, 09:23 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
think I paid $135 for my first set of aluminum wheels back in 83, you just got the 2 halves. you had to either bolt the halves together or weld them together yourself.
482, belt drive, 11 hp Briggs. are you putting gear drive rear in it and Kohler power?
Old 02-19-2013, 09:24 PM
dvogtvpe's Avatar
forgot to mention that they weren't polished either
Old 02-20-2013, 12:01 AM
Dvogtvpe yeah i swapped the 3speed trans in an 10hp kohler for now an yeah i pulled it last year with the 11hp but it bored itself an blows nothin but smoke now an it didnt pull that good but im not putting aluminum rims yet just a stocker this year and immma put 23x10.50-12 ag tires on my 12x12-12 rims
Bi-Polar Plowboy Plowboy X Press
Old 02-20-2013, 12:20 AM
Im trying to find out where to bolt up the clutch release arm braket an im also trying to figure out cause i bought a narrow frame clutch if i need to buy a coupler to make it longer or if itll work the way it is
Old 02-20-2013, 10:23 AM
jmroy's Avatar
jmroy jmroy is offline
What you'll need if you want bolt on parts is the clutch setup from a 582. The 582 has a different clutch hanger and release arm than the narrow frame models. 582 clutch diagram: http://www.partstree.com/parts/?lc=c...&dn=0027200011
Complete clutch setups show up on eBay every now and then or most of the parts are still available new.
Web Developer - Need a website? Contact me.
Old 02-22-2013, 01:37 PM
Thanks jmroy ill look into it
