Old 03-07-2022, 11:25 AM
Shadowfax419 Shadowfax419 is offline
Default LT 46 just quit starting
Hey folks, I've got a 2018 46 that just quit starting. It is getting gas and spark on both plugs. The air filter is clean and I tried bypassing the seat safety switch. I'm stumped. Any ideas? Thanks in advance for the help!
Old 03-07-2022, 12:09 PM
If you could help us out with a little more info that will make it easier to
help you. Like is there no power at all? Does it crank over but won't fire?
Are you sure that the battery has full charge?
There is more then likely all kinds of safety switches on it. Like brake, PTO,
seat, maybe even the chute. Don't know the particulars of that machine.
Do a little research and let us know what you find.
Ken
Old 03-07-2022, 12:37 PM
Inactive Member
I've got a 2018 46
Old 03-07-2022, 06:46 PM
My bad... should have been more precise. It's an XT1 mower. It turns over fine, battery is charged. It ran and cranked fine until I shut it off. Went to crank it a few minutes later and it just turns over. I pulled the plugs and checked for spark, both have a strong one. Pulled the fuel line from the carb side of the pump and have solid fuel flow. New air filter...
Old 03-07-2022, 06:55 PM
Farmall450's Avatar
That's weird. Normally when they randomly stop it's something electrical, which would have killed spark. I assume your tractor has the Kohler 18HP Courage?
Old 03-07-2022, 08:19 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
Carb has a solenoid that requires 12v
If engine is turning over its not a safety switch.
JD x475
Old 03-07-2022, 08:41 PM
Billy-O's Avatar
Billy-O Billy-O is offline
That has to be the BINGO answer. Solenoid could also be malfunctioning.
Plow blade
#2 Cart
QA36 snowthower
Old 03-08-2022, 07:01 AM
ironman's Avatar
ironman ironman is offline
also
1. crap blocking carb needle inlet....
2. carb float needle stuck closed....
3. flywheel key sheared....
Squirt some gas in the carb throat, crank,
if it fires and dies you've got a fuel problem.
Old 03-08-2022, 09:32 PM
Farmall450's Avatar
Originally Posted by ironman View Post
also
Can't say I've ever seen a sheared flywheel key on anything that's not directly driven off the crank (e.g. pushmower). It's tough to diag, though.
Old 03-09-2022, 07:38 AM
ironman's Avatar
You're the expert so,
All readers, please disregard my input.
