1811 PTO Side crankshaft seal
I had an oil leak on my 1811, and believe it's leaking from the PTO side crankshaft seal. I remove the PTO (thanks for the help with that) and it was loose in there, so I'm assuming it was bad.
When putting the new one back in, should I put any sealant on the outside edge? Also, how do you all make sure you've got it the correct depth and in straight? Every seal I've ever put in have a bottom, but it appears this one could be drove in a long way. I tried to find the tool like the manual says to use, but I couldn't find one on the internet. |
You can use t a piece of PCV pipe to drive it in. Be careful and make sure the lip gets on the journal right or you'll ruin the seal. If the outside of the seal is rubber (Or "rubbery" sorry don't know how else to explain) then no, do not put anything on it. If its a steel seal, then you can use some sealant on it. NOT RTV, use anaerobic sealer or hard setting gasket maker. Just drive it in a little past flush. IIRC, there is a lip on the PTO base that has a boss that fit's into the seal cavity to center it.
