Old 06-17-2023, 05:51 PM
Pray-2-miss-rocks Pray-2-miss-rocks is offline
Default 1861 grill interchange w/ other models
Forgive me for my ignorance, but, the cub models are pretty confusing to me since they're so abundant. What other model grills will fit my 1861? Need a replacement.
Old 06-17-2023, 06:00 PM
1440,1641,1541,1860,2284, basically any cyclops series tractor grill is the same except for the diesels.
Up to 530 and counting...
Old 06-17-2023, 09:27 PM
thank you much darkminion.
Old 06-17-2023, 10:54 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
All of the 1782's I have come across had the same grilles as the gas powered Cubs. They had the hole for the exhaust pipe to go through.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 06-19-2023, 05:33 PM
Farmall450's Avatar
Pretty sure mine has the pointless hole, too.
I was under the impression all Cyclops used the same grille.
Old 06-19-2023, 06:12 PM
I know this because I had 2 nos ones with no hole. heheheheh can't seem to find it in my pictures. It actually has a continuation of the grill fins through the middle of the hole.You remove that for use with non diesels and such.
