Old 08-22-2021, 03:35 PM
WayneD WayneD is offline
Question Cub Cadet 149 Crawler
Work done with good tracks and sprockets and dozer blade. Hyd worked ok. Added 3 point hitch but now hyd does not work properly for dozer blade or 3 point hitch. What is the problem? Hyd fluid reservoir not large enough? or what is the problem. Not trying to use front dozer blade and 3 point at same time and still won't work properly. Suggestions please.
Old 08-23-2021, 08:21 AM
Hairtrigger's Avatar
Hairtrigger Hairtrigger is offline
It would be interesting to know what valves are used and also check pressure
Tags
149 hyd lift problem
