Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 08-06-2020, 08:19 PM
Getter-Done's Avatar
Getter-Done Getter-Done is offline
Default Carburetor hose (location) ?
Working on new to me Cub Cadet 1641.
1641 (145-653-100) - Cub Cadet Garden Tractor (SN: 821060 - 880000)
Model #303447 Type 0447-01 Code 940916
Just notice there was nothing going to this Vacuum port in picture below.
Where does this go?
Thanks in advance.
Old 08-06-2020, 11:19 PM
That is the overflow for the carburetor float in case the float gets stuck open the fuel comes out of it.
Up to 530 and counting...
Old 08-07-2020, 07:24 AM
Thank you.
Old 08-07-2020, 09:46 AM
There is no hose on that elbow but I believe there should be. If gas dribbles out, it goes right through the engine cooling fan and blows it straight out the front past the muffler.
Old 08-07-2020, 06:48 PM
I will route one somewhere.
Thanks for the info.
Old 08-08-2020, 07:33 PM
Okay
Now I have a fuel /emission hose neatly routed to the bottom of the tractor/
on the float overflow tube.
I replaced the crankcase breather tube and top gasket.
I was putting the breather base on and
This bracket in the picture below seems to be to tall.
it will bend the breather base if I tighten it down.
Is this normal?
Old 08-08-2020, 09:10 PM
Maybe you have it turned the wrong way?
Old 08-08-2020, 11:39 PM
I will take a picture.
There is a bolt that is striped out/ that may be causing the problem?
So
I will check that to see if it
Old 08-09-2020, 05:36 PM
The bracket turned the other way is a whole lot better.
Thanks Mike
I got the bolt issue fixed.
Now I will fix the PO's wiring mess.
Then I will be up and running.
