Sloppy steering on 129 overcome
A combination of replacing the cam follower, tie rod ends, installing a thrust bearing, and a lot of grease in the steering box, is not power steering by any means, but a lot less play, and more immediate response.
YUP, usually makes steering a lot easier. Good to hear about your outcome.
Randy
2 original cub cadets 1 100's 2 149's 1 73 1 2182 |
I had tried that before all the other work....would really like to replace the front axle with one with 1" spindles
One time I had one that had worn the end of the bushings so bad, I had to grind some off the axle to get the bushings to rotate again,,, I have never purchased a GT that did not need the bushings to be driven out and cleaned,, |
Yeah...I was lucky they were both snug fitting...no wobble and not jammed in....replacements are available from a few guys that specialize in Cub steering parts
