Front steering repair and foward reverse pedal on 109
Long time reader but this is my first build thread. I'm not a purist by any means when it comes to this stuff and I'm all about function over beauty. So here it goes. I picked up this 109 with a blade on it for just taking care of our neighborhood. When I got it the steering wasn't impressive by any means, the front axle pin was wallard out and I hate trying to operate the plow, steer and go forward or backwards with only two hands. So I started by replacing all the tie rod ends. Then I pulled the front axle off. I found that the section of frame that supports the rear of the pin was all beat up and had wore a large hole. So i made a new pin that was undersized and made of case hardened shafting, made bushings to go in the axle, front collar and made a rear block to weld to the frame to replace where the hole got wore out. So far so good all I need to do now is weld the block on. I also pulled the steering gearbox and cleaned up the guide pin and reassembled everything.
As for the forward and reverse issue I'm building a pedal setup to go in it. So far here is what I have done. The second to last picture is my pedal setup. Two blocks welded inside the frame with the old linkage running thru it out the right side where the pedal will be mounted. The old bracket will be used on the shaft to connect to the linkage to the hydro and c clips will hold everything in place. Thanks guys for all your inspiration. WatchiWatching everyone else's posts is my motivation. |
Sounds like your pedal will make things much easier for you...good luck with your build and thanks for sharing!
Paul F Infantry Veteran Original...100/123/147 custom...149 FEL...782D...1282...1864...2182G |
Never been a huge fan of hydros because I feel like I need 3 hands haha. Very interested in this project. I've only seen it on a 129 loader tractor where the lift arm was removed and that rock shaft became the pedal. I cant wait to see what route you are going with it.
nice work on the front axle also. definitely a weak point.
Thank you everyone. It's been slow but I removed the linkage from the forward and reverse that runs through the tower down to where it mounts. I sandblasted it and am finishing up my support blocks for it. I will drill a 1/2" hole on the right side of the frame in front of the rock shaft then tack weld my support blocks inside the frame. Using the old linkage from the tower as my linkage for the pedal. The hardest part I think is going to have clearance for everything but I think it will fit. I will try to get more pics today of it.
Will definitely watch this. Both of these projects, are on my to do list. Working on the rear half of the tractor now.
Steve |
