Old 04-23-2023, 09:49 AM
Ian181 Ian181 is offline
Default 1862 deck stop cam lock
I have an 1862, when I lower the hydraulically operated deck the cam lock moves, allowing the deck to go lower than I want it, even though it's tightened. What's causing this?
Old 04-26-2023, 07:30 AM
dale c. dale c. is offline
is the lift linkage pinned solid for down pressure ?
Old 04-26-2023, 07:47 AM
I'll have to check. I know when I tighten the cam lock knob as tight as I can get it, and then raise and lower the deck again, if I don't watch closely it will push the can stop and go lower than I want it. This is my niece's mower, she can't have this changing constantly when she raises and lowers the deck.
Old 05-02-2023, 10:47 AM
Is it normal to pin that? You do mean where the adjusting hangers go?
Old 05-04-2023, 07:23 AM
at the end of the hyd. cyl. the lever that connects the lift lever to the cyl. 1 pin is necessary it lets the lever pivot if it has a second pin down about 2 in. from the hyd. cyl. it can't pivot giving down pressure for a blade. also make sure you're rotating the deck stop correctly one way may let the cam rotate when weight is against it
Old 05-04-2023, 07:52 AM
goonpeden goonpeden is online now
What you can try if the lift linkage isn't pinned, install a 3/8 fine threaded bolt with a flat washer instead of using the knob, can get it alot tighter with a wrench or socket than with the knob. Works for me!
Old 05-07-2023, 08:58 PM
Thanks, I'll check it out.
Old 05-15-2023, 10:02 PM
Pray-2-miss-rocks Pray-2-miss-rocks is offline
What does it mean to be pinned? As opposed to what other alternative?
Old 05-15-2023, 10:46 PM
When it is "pinned" you have down power,--- say to use with a front dozer blade.
Or rear down power.
Un pinned the lift is free to float but it still has lift power, just no power down.
you don't want down power on a mower deck, just power lift.
Clear as mud?
Old 05-16-2023, 07:55 AM
olGeorge, excellent answer, thank you. I haven't had a chance to check it yet (it's my Niece's), but I will look for that.
