Old 05-31-2024, 12:43 AM
W4cnv W4cnv is offline
Default 1782 Hy-Tran coming out of dipstick vent
Hello all, I’ve had my 1782 for a couple of years now and since day one at least once or twice during the mowing season it will puke hy-tran out of the vent hole in the dipstick. It kind looks like a small geyser ?. Anyway I don’t believe it is overheating because the oil is only warm to the touch and the rear case is only warm. Any ideas would be appreciated.
Old 05-31-2024, 06:30 AM
My guess is that you need to remove the fender pan and fuel tank and give it a good cleaning. Next if you have not changed the fluid and filter do so.
Other possibility is that it's overfull. Just a thought but at some point in it's life someone my have replaced the dipstick with one from a GT and they are about 1" shorter than the Super dipsticks.
Old 06-01-2024, 06:19 AM
The 1st pic is what you will probably find when you remove the fender pan.
The 2nd pic shows the vent that was incorporated into the later Cyclops series.
The 3rd pic is how I add a vent if it doesn't have one.
Old 06-05-2024, 09:25 AM
Sam you are the cyclops guru. That first picture is almost exactly how mine looked before I fixed the leaking fuel level grommet and front hydro seal.
The last picture is what I believe i'm going to do to mine as well. It's an early model and the only vent is the dipstick and I'm thinking it's just building more pressure than the small hole in the dipstick can remove. Did you drill and tap a new hole or use an one already there?
Old 06-05-2024, 11:36 AM
I drilled and tapped one of the bolt holes that are there for the rear PTO. This was an 1882 that I did. You'll also notice how far the dipstick protrudes into the case. Check yours when you have the cover off.
