Old 06-01-2022, 01:59 PM
Farmall450's Avatar
Default Resurrecting the Yellow & White CCC 984
Greetings,
I figured I'd make a new thread to document the 984's return to service after sitting almost 20 years.
Attached is the tractor how I found it, then it's status last night. Rear tires are off as I cleaned/am painting the rims in preparation for new Carlisle Multi Trac CS Lawn & Garden Tires (Rear - 26X1200-12 LRB 4PLY; Front - 18X850-8 LRD 8PLY).
I plan on pressure washing the rest of the tractor and getting tires on it before any real use. The cab (headliner), fuel tank, and fuel lines were in sad shape when I got it. I also have some wiring "modifications" to undo in the immediate future. The engine is a Liminar/Onan Performer 20 crate engine put in right before the tractor was parked.
Farmall450's Avatar
For reference: https://www.onlycubcadets.net/forum/...ad.php?t=60031
Old 06-01-2022, 03:10 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Cool
Love your rare 984.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 06-01-2022, 04:18 PM
Farmall450's Avatar
Originally Posted by 1711Cub View Post
Love your rare 984.
Thanks. I think it'll look cool next to the yellow 782, which I'm also working on.
Old 06-01-2022, 07:08 PM
Farmall450's Avatar
Back on track -- canvas white is not the near match I read it to be, unless it dries significantly darker.
Pressure washed, wire wheeled, wiped down, and primed the rear rims. New tires arrived today, so hopefully I can finish paint tonight and mount tomorrow after work.
Old 06-01-2022, 07:20 PM
twoton twoton is offline
Old 06-01-2022, 11:15 PM
SS5150's Avatar
SS5150 SS5150 is offline
I used Valspar IH white from Farm & Fleet, & the color wasn't bad (I started using it on my Y/W 782) but the cans suck, and I'm not sure F & F handles it anymore. I ended up running up to Otter & springing for the IH IronGard paint.
I've got a can of Krylon IH white here too, but I can't remember what I used it on, or where I got it. Probably used it on the wheels on my 1050, and they don't look bad. I don't recall the paint itself being a problem either.
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 06-01-2022, 11:22 PM
Farmall450's Avatar
I ran out of Iron Guard and wanted to find something local. At one point Farm & Fleet stocked CCC Yellow and White plus the valspar then rustoleum clones. It seems that is not the case anymore.
I did get the homemade door off the Sims cab and the whole tractor pressure washed tonight. Tomorrow I want to dial in the rear brakes and possibly mount the rear tires/dismount the old front tires and prep them for paint. Still not sold on this color for the "white", but sending it for the Y/W 782's rear ag tires.
Old 06-02-2022, 01:24 AM
Sergeant's Avatar
Sergeant Sergeant is offline
I Have found rustoleum Almond to be about the Closest Match
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force
Old 06-02-2022, 07:33 AM
1711Cub's Avatar
Lightbulb
The Rustoleum Almond is VERY close to the original 80's Cub cream. I've used it several times and have been pleased with it.
