Spring assist ideas?
Today I mounted my blade to the front of my tractor. UGH, its a little heavier then I expected. Other then buying a spring assist (which may just be the best solution right now) anyone just make one? Id rather not spend a ton of cash on this right now or make it to complicated. I do have one of those HF Sam special winches that I have thought of using but again, a little more complicated then I want to go at least this season. Does the spring assist make much difference?
108 upgraded to 12hp 127 with all the trimmings 73 WIP 75 WIP Blade, blower, decks Tons of left over parts |
Spring assist makes a big difference. When I had my 122, I had both the IH spring assist and the Brinly spring assist on the lift bar and it was great. Almost effortless.
If you can find the bent rod, a newer spring assist spring works. |
Just found this thread here. CAD, you ever build this out?http://www.onlycubcadets.net/forum/s...ad.php?t=15214
Huh
That will not work on a wf.
the winch takes too long to lift.plus you have to figger a way to mount it. Why not just get a correct one for your 108?
This is how I'm leaning but they seem rather expensive for two brackets, a spring and a connecting rod :-(
Yes i know,but it works.
need one?
I'm going to have to do something because this blade is heavier then expected. The first few times I picked it up I thought I could just live with it but then I thought about how many times I'd be lifting this thing all winter and realized I better think of something. So, yeah, I'm shopping.
You can get some dumbells an give your right arm some more muscles.
Like Popeye
