Old 09-08-2024, 12:01 PM
jesse c jesse c is offline
Default 2182 temp switch
my 2182 throws the temp light on dash after about 20 mins of run time. i always shut down quickly and let it cool. It has never boiled over and wonder if it could be a faulty temp switch. I would just replace it but that switch is no longer available. Any aftermarket part # that would cross reference?
Old 09-08-2024, 01:33 PM
Billy-O's Avatar
Billy-O Billy-O is offline
It also makes me wonder if you have faulty thermostat, water pump or clogged cooling system. Is the radiator hot after 20 minutes?
Without knowing your serial #, for a switch on the earlier models there seems to be many hits for a temp switch. Verify before buy: https://www.fridayparts.com/temperat...IaAjulEALw_wcB
Plow blade
#2 Cart
QA36 snowthower
Old 09-08-2024, 07:38 PM
Cooling on the 2182 and the 1782 is marginal at best. Check everything T stat, pump, radiator and screen. I put a temp gauge in my water pumpers and I also added Red Line water wetter to the coolant, you can get it at most auto parts stores.
