Old 09-25-2023, 11:57 PM
Round Fender Round Fender is offline
Default Cub Cadet 73 instrument panel
I have a 73. I have some work to do it. It has previously been “re-done”. I was hoping someone would please post pictures of their 73 instrument panel so I can see what it is supposed to look like.
I am adding pictures of mine so you can see what may be off. Is the large hole a factory thing, or is this where someone enlarged the hole? Also what items go on the instrument panel? Is it an ignition switch and a cigarette lighter?
Thank you in advance.
Old 09-26-2023, 08:29 AM
ironman's Avatar
ironman ironman is offline
You are correct,but the big hole is for the ignition switch and would require parts # 15 & 16.
Small hole is for optional lighter which may use a filler plug.
Old 09-26-2023, 11:08 PM
Thank you, Ironman. I’ll try and find those parts.
Old 09-27-2023, 09:32 AM
That diagram is a bit misleading as the switch actually goes in from the rear of the U clamp, part #15.
From left to right: (bottom photo)
switch (17), U clamp (15), nut
Then insert the assembly into the dash from the inside, then the cup, (16) from the outside, held by another nut, from the outside.
I like that setup as it protects the key when in the switch from damage from my gunboat boots!!
Wish they were all that way
Old 09-27-2023, 11:45 PM
Thank you finsruskw. The diagram is great, and now the photos clear it up more. I am thankful for both the diagram and the photos. I agree, the photos offer a better understanding of the parts and assembly. You may be surprised how hard it has been for me to try and find a picture of a 73 instrument panel - a picture that is close up and clear. Thank you for the reply post.
