Compressor motor repaired....finally!
You can see my lonely compressor, sans motor, in this picture. The motor stopped starting, and I thought it just needed new caps. Took it to the motor shop (in early October), and found that the big 5hp GE motor, and all it's parts, were obsolete. New motor was $4-500. It turned out that it wasn't the start caps, even though they did get replaced due to cracks, but a switch. A NLA switch was bad, but they found one that works and put it all together, along with new bearings and a few other refurb items. I'm looking forward to getting it back on the beast and running. I may spring for a new tank, since the original is around 40 years old. The pump is a 2 stage/16+cfm @ 175 psi, Champion 15rb and parts are still available so I may give it a rebuild in the spring. It should last another 40 years without any problem.
Kubota B7100 HST 4x4 w/FEL, 4' Bush Hog, Woods RM400 Finish Mower Original Member #54 |
Those big industrial quality motors are always worth rebuilding.
They will out work todays throwaway china junk every time. I'm glad you were able to find a rebuilder who took the time to fix it. Looks like an old Dayton. |
that looks lick a heavy duty compresser , nice shop also
