Old 05-11-2011, 09:44 AM
TBrown TBrown is offline
Default why does it shut down
Hello I'm new to this forum and new to cub cadets ..I got two cub cadets from a good buddy of mine . One needs a carb and a mower deck .. so if u have one let me know . And the second one will run for about an hour or so then lose pressure and like sputter out .. they are club cadet 100's I believe 77?? If that sound right .. I live in Toledo Ohio .. thanks
Old 05-11-2011, 11:58 AM
Welcome to OCC! Glad to have you! If you have 100's, they were made between 63-65. Also, if you're looking for a mower deck, please post a wanted ad, in the Wanted Items section of the site.
Old 05-11-2011, 01:51 PM
Oh nope I was just hoping someone knew why it would shut down
Old 05-11-2011, 02:20 PM
westofb's Avatar
westofb westofb is offline
I believe I have heard others mention these symptoms before, if I remember correctly they stated the problem was most likely a bad condensor, or it could be a bad coil.
Keep your pants on, someone will chime in soon enough with some insight to your problem (some folks have to work you know....LOL)!
Oh, and by the way welcome to the site, you will find alot of useful material on here, check out the manuals section, you should be able to download a manual for your tractor, and the kohler engine...they are great for looking up how to maintain and repair you cub!
Jeff
Brookfield, MO
________________
Old 05-11-2011, 04:03 PM
Sounds like a coil but a hour is a long time for it to shut off. You can try the coil from the other 100 and see if that helps it.
Follow Allen's advice and place a want ad in the wanted section of the site and you'll have alot better results.
Old 05-11-2011, 08:25 PM
Is the fuel tank vented? Try and loosen the cap and see if that helps.
Old 05-11-2011, 10:42 PM
I'll have to try the tank vent .. do u think that marvel mistory oil would help? Yeah I'm going to try the other coil .. hope it works I'm so pumped .. I will post a pic once I get it all washed and dirt free ...
And i work full time just love my smart phone Haha ..
And would u re paint it or clean and wax it up ?
Old 05-11-2011, 10:49 PM
Try a new condenser also. Make sure the points are clean and fresh. Some light sandpaper can clean them up. They could have some buildup.
Old 05-11-2011, 11:40 PM
I had a JD that would do the same thing and it was the coil in it (I know....I'm embarassed to admit it, but I owned one at one time....haha). However, the others have given you some great advice already that would also help make sure that it runs fine. You may also want to trace your wiring, if it has been spliced anywhere, it might be losing contact as it heats up through expansion....this also happened on the wire to my condensor on my JD. LOL (Lots Of Luck!)
We don't need them all polished up to see them, everyone appreciates a hard working cub!!!
Old 05-12-2011, 03:19 PM
Okay I checked my wires nothing . I changed and cleaned the coil . And when I shut it off I noticed a gurgling sound .. come to find out the gas in tank is boiling .. it has a non stock muffler on it .. would that cause it to boil the gas ?
Tags
cub 100
