Old 06-25-2011, 09:10 PM
sodbuster sodbuster is offline
Default rear pto
I am wanting to install a rear pto on my original. what do I need to do this? is this a bolt in project?? or do I need more than the pto? trans parts,shims,etc...
Old 06-25-2011, 09:48 PM
samspops samspops is offline
Red face
HI, nope, its not a bolt on deal.the prob is that the upper shaft in the tranny needs to be drilled and bushed. i'm not sure if teeth need to be hobbed into the shaft. there is a fella that will do your shaft for about 95.00. then the rest is pretty painless. DO NOT fall into the "it has to be from a cub cadet" mantra. you can get the whole pto set up for a farmall cub pretty cheaply on ebay. if you see one on ebay that is for a "cub cadet" get ready to pay 250.00 or more. or get one for a cub for less than 50.00 sometimes. then the other difficulty....the pto shaft turns the opposite direction. then you need a reverser...250.00 & up. good luck with the project.
Original Cub Cadet/creeper/fluid filled ags/3 rib fronts(Third one I've owned)
Ih rear blade and rake
MF 10/3pt/all the toys(sorry but i like it)
MF 12 under construction(sorry but i like it)
IH 560 tractor
'47 Ford 8N Tractor
'85 Ford F 250 7.3 IH idi diesel
'99 Chetech Pug 4X4
Jari Monarch sickle mower
