Old 07-31-2011, 01:11 PM
bridgewatertek's Avatar
bridgewatertek bridgewatertek is offline
Default question about 1450 ignition switch
can anyone tell me what the terminal letters would be for an ignition switch for a 1450? I need to get a new switch, and my dad in TX has some switches, I just need to get him the letters. Thanks in advance.
Jim Bridgewater, KD0FJO Osage, IA
1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab
Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow
Old 07-31-2011, 08:51 PM
steveyrock's Avatar
steveyrock steveyrock is offline
http://www.cubfaq.com/wiringdiagrams/1450.jpg
122-snow blade and 42 deck, wheel weights, fluid filled tires,chains
106-42"deck
1250-44 and 50" decks
147-44"deck
2155-42"snowblower 38"deck, chains,suitcase weights
Exmark Quest-zero turn 42"deck 23hp Kawasaki engine
Old 07-31-2011, 10:10 PM
scgtguy's Avatar
scgtguy scgtguy is offline
Default switch
FYI ... I found that 1450's have different switches year to year ... different number of prongs ....
B.
Old 07-31-2011, 10:43 PM
Thanks steveyrock, I knew I saw that somewhere, just couldn't remember where. scgtguy, there may be 5 prongs, but there are only 4 wires coming out of the harness.
Old 08-01-2011, 12:34 PM
There was only one Ignition Switch that IH used on all the Quietline models, that being: IH-61524-C3..
The correct wiring diagram for the Q/L is located here..... Wiring Diagram
The part can be obtained from your local Cub Cadet, Case-IH dealers, or the Sponsors in the boxes above, will gladly help you out.
Old 08-01-2011, 05:47 PM
steveyrock's Avatar
is this one not correct? http://www.cubfaq.com/wiringdiagrams/1450.jpg
Just for my records.
106-42"deck
147-44"deck
Old 08-01-2011, 10:43 PM
scleve scleve is offline
Don't forget to check placement of the terminals. Letters may be right but in the wrong place for the wiring harness plug.
