Old 08-14-2011, 01:43 PM
MrGitrdone41's Avatar
Default 128 not running need help
What it does is it will not run without the choke and runs rich. I have a new carb on it. I cleaned it and checked the seat and checked the timing it is dead on. I adjusted the valves back to spec. Intake 8 thousandths, EX. 18 thousandths. Here is the link of the vid of it running. www.youtube.com/watch?v=aVENHc9g_tY
1988 1812,dual ports
1973 108
1968 125
Old 08-14-2011, 02:13 PM
Originally Posted by MrGitrdone41 View Post
What it does is it will not run without the choke and runs rich. I have a new carb on it. I cleaned it and checked the seat and checked the timing it is dead on. I adjusted the valves back to spec. Intake 0.08, EX. 0.18. Here is the link of the vid of it running. www.youtube.com/watch?v=aVENHc9g_tY
Gasket leaking around the carb? Fuel delivery problem?
Old 08-14-2011, 02:18 PM
'will not run without the choke and runs rich' is a contradiction. 'New carb' as in one of those worthless non-adjustable Walbro carbs?
Unless you mis-typed your valve lash numbers, those are completely wrong.
Old 08-14-2011, 03:14 PM
Matt what is the right adjust for the valves?The carb is a Walbro but is adjustable.
1973 108
1968 125
Old 08-14-2011, 03:40 PM
It would be helpful to shut off the music and the child when making the video.
Then adjust the valves to .008 and .018
not .080 & .180 as typed or is that a typo?
Hand choking it will make it rich.
cubs-n-bxrs's Avatar
Mrgiterdone you are probably allright on your adjustment. I watched the youtube video. The way you have it wrote is 80thou and 180thou. You forgot to add zeros after the decimal point. I would also check your head gasket. A blown head gasket will give it the same symptoms. Did you reuse the carb gasket when you put on the new carb? Old gasket could possibly be damaged. And the last thing did you have the motor in the right place when you set the valves?
Old 08-14-2011, 06:45 PM
Sorry about that typo. The head gasket is new and the head is flat. The carb gasket is new also. The motor was out of the tractor when i adjusted the valves. I maybe bumed it .I'll recheck the valves. Thanks for your help!
1973 108
1968 125
Old 08-14-2011, 10:25 PM
I readjusted the valves. They were way out of spec. The book said to put the motor TDC. I put the T on the flywheel in the sighthole then adjusted them is that right?I'll try to start it 2mro.
1973 108
1968 125
Old 08-14-2011, 11:09 PM
Good luck, Sam!
Old 08-16-2011, 04:56 PM
do you have a good flow of gas to the carb ? and good new gas ? will it start and run for a few seconds ? would it run if the choke was set half way . throttle open wide? at carb. that might explain needs choke to run and runs rich . you adjust the valve clearance after the cam has opened & shut the valve
128 owner myself
