Old 09-05-2011, 10:44 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
Default 882 Diesel "refreshing"
Well I have finally had some time to start working on the 882 this weekend. I have been collecting parts over the last week or so. I have the updated starter (current one has a bad solenoid), a new alternator and voltage regulator (Old regulator no longer working) from xtrememotorworks, and parts for the glow plug upgrade. I have not got too far, mainly just torn down and ready to lift the engine so the old starter can be removed. I bought my 882 locally from a guy that was given it as payment for doing some wok for another guy. From what I can tell it has sat a long time.
I noticed that the battery tray is very rusty, and since I had just finished my electrolysis tank (thread updated as well), I figured it was the perfect time for it to take a bath.
IMG_0899 by yamaguy, on Flickr
I think the old battery was left in there a long time and melted down.
IMG_0908 by yamaguy, on Flickr
Also If you have hub caps, maybe take them off more than once every 20 years...
IMG_0917 by yamaguy, on Flickr
the wheels would of been in much better shape if not for the hub caps
IMG_0918 by yamaguy, on Flickr
Hopefully I will be able to finish it up this week or next.
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 09-05-2011, 11:09 PM
You've been busy, Dale! Looking forward to your updates.
Old 09-06-2011, 05:54 AM
Vince_o Vince_o is offline
HOLLY CRAP BATMAN!!!!!!!!!! Look at them wheels, I wonder what mine look like
Old 09-06-2011, 07:34 AM
Maybe I should take mine off too and see what's in there!
Old 09-06-2011, 07:54 AM
Gives me second thoughts about hubcaps...
Old 09-06-2011, 09:17 AM
aagitch's Avatar
aagitch aagitch is offline
Holy crap is right! Those things are horrible!
Adrian
2072 (789513)
Old 09-06-2011, 09:35 AM
Thanks for the pics Dale! I'm so looking forward to this thread!
Old 09-06-2011, 11:46 AM
juniors1282's Avatar
I took the one's off the parts donor 1806 a few weeks ago and there was nothing in there but a couple cob webs. wheels looked brand new behind them. Looks like it sat outside for quite a bit and little mouse made himself a big old condo in there to me.
1966 IH cub cadet 102x2
Old 09-07-2011, 10:36 PM
Yamaguy's Avatar
I had more time today after work to make some progress. I got the battery tray painted, jacked up the engine and replaced the starter, along with drilling the hole in the motor mount plate, and resecured the engine to the tractor. Up next will be installing the new alt and regulator, new fuel lines, changing all the fluids, reinstalling the battery tray and then figuring something out with the throttle cable that is broken. Nothing really to take pics of.
Dale
Old 09-07-2011, 10:54 PM
Yamaguy's Avatar
I found this the other day, but didn't post it up.
After I took the tunnel cover off the 882 I was inspecting the drive shaft joints and I happened to notice that the hydro input, rear joint, and fan will turn freely independent of the drive shaft. The fan is bolted to something that may be a fluid filled clutch to aid in starting. When I start the tractor the hydro does not turn till it fires up, then it spinning like normal. My question is that I thought that only the later diesels had a disconnect clutch, not the early 782D, 882.
IMG_0901 by yamaguy, on Flickr
The tractor works like it should, so nothing is broken as far as I can tell.
Dale
