Old 10-03-2011, 07:03 PM
guido guido is offline
Default QA36A Belt?
Hiya Folks,
Picked up a QA36A last night for my 127 which has a brand new auger, runners, chain, bearings, and U-joint assy. It also came with some extra parts. An auger, housing, lift bracket, plate assy, pivot plate assy, and gearbox plate.
All I need is a belt. CC website lists two belts...
*IH-55053-C1
*IH-78056-C1
Any know which is suitable for use with my 127?
Regards, Guido
Old 10-03-2011, 08:54 PM
This One: *IH-55053-C1
Old 10-05-2011, 04:52 PM
Thanks DX.
Old 10-05-2011, 08:58 PM
Default More Question???
While I was adjusting the QA to fit my narrow frame I noticed a few thing that need attention.
1) there is about 1-1/4" to either side of the bracket/plate assy. allowing lateral movement on the pivot shaft.
I think some 3/4" ID sleeves are needed here/
2) the top links are fabricated replacements and missing the slot in the middle.
Can someone supply dimensions for this piece?
3) THe housing serial plate states that the unit is a "QA-36B".
Just curious about this one.
Regards, Guido
Old 10-06-2011, 06:33 AM
The QA36B was designed for the 82 Series Cubs. It will have a 5/8" drive belt and a curved upper linkage.
Old 10-06-2011, 06:52 AM
Thx RBedell,
The housing is the only part that is designated series B. The seller also gave me the original housing which is an A.
regards, Guido
