Old 11-12-2011, 10:46 AM
rlueders rlueders is offline
Default Cub 149 creeping
I have a strange issue with my 149.
I've done the trunnion repair and replaced the speed control cam because it was sloppy. I've done the neutral adjust and when I use the tractor for some reason it starts creeping again. I have done this a number of times and get the same result.
Anybody have this issue?
Thanks
Richard
Old 11-12-2011, 09:00 PM
Sugarmaker's Avatar
I had to go through this on the 147 and it seemed like the trunnion repair may have been the primary thing. I also adjusted the brakes per the book which is a little bit of guess work with worn brake pads. The n brought the cam bracket to the top of the stroke and tapped down till the tires stopped . The combination of all those is working for now. Good luck.
If I can help P.M. me.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
