Old 11-23-2011, 11:07 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Default Dash Repair Methods
On my 782D and 1572, the dash is starting to wear pretty badly where the grommet from the hood rubs on the dash when closed. In a couple of spots it has worn through. What are some time proven methods for repairing this wear? I was even contempating using J & B Weld along with a bondo spreader to fill in the gap, then paint it black. I figure if the J & B is rugged enough to tap and drill, maybe it will hold up better than the plastic that was there. ideas?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 11-23-2011, 11:40 PM
I JB'd my 1872 a year ago. I had "almost" through holes.
Looks good so far.
I did it on a warm day. The JB flowed real nice, giving a great surface finish.
For the vertical sides, I let the JB set for 30 minutes before applying. Again, I got smooth surface flow.
Hope you have access to a heated garage in MA, I spent a couple years in Wilmington.
If I would have had through holes, I would have used Fiberglas cloth.
Old 11-24-2011, 12:36 AM
Looks good so far.
Most use fiberglas cloth. Never heard of the JB weld trick but if it works that's all that matters.
Old 11-24-2011, 09:59 AM
Here's what I did.
Old 11-24-2011, 10:22 AM
My 882 dash was trash, then I saw Matt G's repair method and figured I would give it a try. It's not complete yet and it needs a few more layers of JB applied, sanded and painted black. I don't know if it will hold up to the vibration but I'm going to see if I can support the hood off of something else under there.
Old 11-24-2011, 10:53 AM
Oak, that dash looks like you could park a smoker engine on it, good job.
When I "rehooded" my Cyclops with a metal hood, there was nothing to hold the hood up.
I fabricated the "L" shaped bracket that bolts under the oil filter and goes up over the battery.
The black covering is some material I found that was supposed to be used as a shovel handle cover.
The hood is quiet.
Old 11-24-2011, 09:50 PM
FrankF3's Avatar
Matt G that is a real nice doc you have there on repairing the dash. I think I'm still going to use J & B as it seems to be as strong as steel. I had a tab that brok off of the recoil cover on an old Poulin chainsaw that was given to me. I put J & B in the edge where the tab broke off, then let is set for a couple of days for max strength. After that I put in more J & B behind the crack for more strength. Never had a problem with it again.
Old 11-24-2011, 09:54 PM
FrankF3's Avatar
CADPlans, are you happy with the way the J & B is wearing? Is it bonding good to the plastic with no delamination? Do you see the silver of the J & B as the paint wears off? Luckily, I have the dash off and will be "refurbing" it in the cellar where I can get it warmer with the wood stove as needed so normal New England cold shouldn't be a problem.
Old 11-24-2011, 10:25 PM
I carefully put the JB only where the hood covered. I did not paint it at all.
The JB is holding and not wearing, I'm happy, I just do not look that way when the hood is up. Why would I? I got a pretty engine to keep my attention!!
Old 11-25-2011, 05:38 PM
FrankF3's Avatar
CADplans, I figured that with the JB weld being a harder material, it could hold up better. Not only do I have the "ridge" caused but the hood rubbing, but the actual edge of the dash where where the 90 degree bend is that forms a flange all the way around where the hood hits, is worn down paper thin at the bottom edges. That will be fun to build back up.
