Old 01-04-2012, 08:02 PM
krhoover krhoover is offline
Default Snow Plow lift height
How high should the snow plow lift? When I set it up, I drove it up on 2x4's to get some down pressure. It dose'nt seem like it's high enough, only about
3 1/4". I am using the top hole in the lift arm.
Old 01-04-2012, 08:12 PM
What tractor/blade do you have??
This one will clear 6" when the blade is straight (90 degrees).
Old 01-04-2012, 08:20 PM
A 1450, with 44" blade.
Old 01-04-2012, 09:16 PM
Look at this picture. I fabricated a rod with multiple holes at both ends so i can pick the lift height I want.
Old 01-04-2012, 09:17 PM
Thanks, was thinking about something like that.
Old 01-05-2012, 08:47 AM
thenrie's Avatar
thenrie thenrie is offline
That is no light duty rod! That one is man-sized! I bought a 1/2" rod to make one out of. Feeling kind of wimpy right about now.
Tony
Stafford, VA
1650, 682...
Old 01-05-2012, 10:52 AM
Yea, when the "factory" made the Cub Cadet parts, they wanted every ounce removed to save money. Hence the 1/2" lift rod came from IH.
When you or I make it, we can afford the extra $1 in material so we never have to deal with it again. Mine is 3/4" rod with ends fabricated from bar steel welded on the ends.
Mine is not cheap, but, probably still cost less than an OEM one would cost if I could find it!!
Old 01-05-2012, 11:46 AM
Top notch work on the lift rod, CADplans!
