Old 09-20-2009, 10:43 AM
cvcman cvcman is offline
Default 126 QA42A snowthrower belt adjust ?
Ok after mounting the blower and adjusting the belt with the hand screw should you tighten the 4 bolts that mount the pulley plate to the main blower frame.
The 4 bolts are loose so you can adjust the belt they are in elongated holes.
Cub Cadet 126
Old 09-20-2009, 11:06 AM
No, there are spacers in there so the part with the gearbox on it can slide up and down, allowing you to adjust the belt. Those bolts should already be tight.
