Old 04-13-2012, 11:59 AM
Darrell Darrell is offline
Default Drilling a Driveshaft
Hey Guys , I need to make some driveshafts for some cubs i have and since i haven't drilled holes in roundstock in a good while , AND my eyes do not see near as well as i want them to , does anyone have a foolproof way of drilling the holes in roundstock ???
Thanks ,
Darrell
Old 04-13-2012, 12:02 PM
samiam44 samiam44 is offline
Yes,
I would use a drill press and a vice. Mark the center line of the shaft with my caliper. Get it centered and tighen the vice, then center the vice on the line with the tip. Use a stubby center drill(buy from a macinist supply house). The use a regular drill- depending on the final size I might have a reamer laying around to leave a clean hole.
Michael
Old 04-13-2012, 12:13 PM
Thanks for the advice Michael.
I am thinking about getting a lock collar and drilling a guide hole in it and use something like that ???
Old 04-13-2012, 12:21 PM
tservice tservice is offline
What type of roundstock is good to use? I do need to make one for my 127.
Old 04-13-2012, 12:25 PM
I meant the combined center drill/counter sinks you use on the lathe (mainly).
You can use any steel for the driveshaft. I generally don't like messin' with CR as it doesn't leave a good finish naturally on the lathe. Depending on cost.. sometimes I opt for W-1 or O-1 if its not real expensive. Then Hot rolled and last CR.
Old 04-13-2012, 06:55 PM
Don't use hot-rolled...the tolerance on the OD is generally worse than anything else you'll find. I have used cold-rolled in the past with no issues (yes, it warps and does weird stuff when you machine it, but drilling a hole through it won't cause this problem) but I prefer 4140. It machines nice and is considerably stronger than ordinary low-carbon steel.
If you've got an extra driveshaft coupler, you can make a drill guide out of it. I have a picture of the one I made somewhere, but I can't find it. It's basically just an old driveshaft coupler welded to a piece of angle iron. Clamp the guide to the drill press table, align it, put in the piece of metal, and drill the hole. The picture would probably be worth a thousand words.
Old 04-13-2012, 07:14 PM
Thanks for the info Matt. Not sure if i have a coupler around here , but that is along the same line i am thinking.
I did do a search and found quite a few good ideas on how to do the drilling.
