Old 05-11-2012, 03:44 PM
Default 60" Haban front wheels
Replaced the front wheels and spindle bushings in my new to me 60" Haban
Got them from McMaster Carr, just a little less expensive than Cub. Used a longer bushing and the wheels have a cast steel center.
Old 05-11-2012, 05:08 PM
Nice work, Sam!
Old 05-11-2012, 05:29 PM
Nice work, Sam!
And pics too!
Old 05-12-2012, 07:37 PM
Don't think the PO owned a grease gun from the looks of what I took apart LMAO
Old 05-12-2012, 08:07 PM
I think he had a grease gun filled with water!!
Old 05-12-2012, 10:53 PM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
Sam I need to the same would you care to post part numbers for McMaster Carr
Don Smith
Old 05-13-2012, 07:30 AM
Just for you
Part #2938T55 SAE 863 Bronze Flanged-Sleeve Bearing, for 3/4" Shaft
Diameter, 1" OD X 1-1/4" L X 1-1/4" Flange OD
4 each 2.98 $11.92
Part # 8368T57 High-Capacity Rubber-Tread Wheel, 6" X 2", 1/2" &
5/8" Axle, Roller Bearing, 820# Capacity
2 each $22.87 $45.74
Merchandise $57.66
Old 05-13-2012, 10:34 AM
dsmithjr's Avatar
Thanks Sam Ill do the same when I rebuild me deck
Don Smith
Old 05-18-2012, 06:33 PM
Got the wheels back on the Haban. Had to replace one of the casters. The deck had two left hand casters when I got it and one of them had been broken and badly repaired, figured it was going to be more trouble to try to fix it than it was worth so I got a right hand from Cub. Now they paint them rather than the galvanized that they used to be, go figure. Just need to weld a crack in the rear hanger bracket and then get it cleaned and painted.
Old 05-18-2012, 07:27 PM
Looking great, Sam!
