Old 05-17-2012, 07:53 AM
mickb72 mickb72 is offline
Default mag 18 spec# 24585
Hi all, i have a mag 18 spec# 24585. Where can i punch in that # to find crankshaft dim. I haven't had much luck on kohlers site. I pulled the bolt from the electric clutch on front and it looks to be 1"? I would like to know dia.x length for sure and what it was spec. for. I want to put this in a 582 and use that elec.pto, or if it is 1" would the elec. pto off the briggs work on the mag 18? Thanks for any help. Mike
Old 05-17-2012, 09:27 AM
Frank1541 Frank1541 is offline
Go to the Kohler site and look it up.
http://www.kohlerplus.com/login.asp
Old 05-18-2012, 08:52 AM
Thanks, better luck this time,found it in the parts manuel.(1x3 9/16)Now to find how close that is to the briggs. Mike
Old 05-18-2012, 10:12 AM
If its 1" shaft and you have a clutch with a 1.125" bore it's an easy fix. You just get a 1" ID X 1.125" OD bushing and some 1/4"X 5/16" key stock. McMaster Carr http://www.mcmaster.com part number 6381K18 for the bushing and 98491A137 for the key stock. Just did it on a tractor I was working on. Had to run a brake cylinder hone through the bore because it was a little on the tight side and also had to run some emery paper over the outside because it was also a little tight for the clutch bore. Then you just cut it to length and cut a slot for the keyway.
Old 05-18-2012, 11:12 AM
M-18 Crankshaft Spec's
Cub Cadet - 24506 had a 1.125" x 2.797"
AYP - 24585 had a 1.000" x 3.562"
You could find a AYP PTO.
Old 05-18-2012, 02:05 PM
Default mag18
Roland,thanks for the cub specs. I have the ayp pto, also the one on the briggs 1" maybe i'll have a spare. Sam, great idea, i've done that on other shafts for things but never thought of a pto. Mike
