Old 10-29-2012, 08:48 AM
Daz0205 Daz0205 is offline
Default cub 122 about to undergo restoration.
My name is Darren, iam 16 and go to trade school. My grandpa recently has given me a 1968 cub 122. I have retaapped the exhaust threads, cleaned out gas lines gas filter carbueartor and the tank several times. This tractor needs to have all wires replaced an ignition switch, and a few other odds and ends. It very obviously need paint but what im wondering is how far shud i take it apart when painting, if there is any tricks to remove a stuck steering wheel and to tighten up the steering is there any pars that will need to be replaced? Thanks for reading.
Old 10-29-2012, 09:28 AM
cubby102's Avatar
cubby102 cubby102 is offline
In my opinion I'd take it all the way down when u go to do the repaint. Right at the moment my 102 has every nut and bolt.removed. but remember to take plenty of pictures for reference to re assemble. Good luck on your restoration you picked a good model to do it with. It's one of my favorites and welcome to the site
Old 10-29-2012, 12:24 PM
Good luck with your grandpa's 122!
Old 10-29-2012, 03:39 PM
ihcc104's Avatar
ihcc104 ihcc104 is offline
Welcome to the site and that is awesome cub cadet to start with! I love the narrow frames! Where about's in CT are you located? I am from East Haddam. Be safe and good luck throughout the storm, the winds are picking up!
- Cory Sanderson
Old 10-29-2012, 07:18 PM
That sounds good guys thanks alot! Also im likIng the site ! Found some pretty helpfull things and love looking through the pictures!!
Old 10-29-2012, 07:21 PM
Oh man almost forgot im not to knowlegable about painting whats a good way to prepare motor for paint?
Old 11-04-2012, 04:15 AM
nikster's Avatar
nikster nikster is offline
What helped me when I took my # 109 apart is;
Plenty of pics in every aspect of any part/wire being removed & every bolt screw, placed in a zip lock baggy marked with a sharpie to identify. There is no way I could trust my memory to do this.
Good luck in rebuilding & post pics.
Nik,
Old 11-04-2012, 08:04 PM
johncub7172's Avatar
Cool
Welcome to Only Cub Cadets! To answer your last post, if that k301 has oil, rust, and loose paint then chances are the paint you choose will not hold up as long and will start to look bad. You dont need to get too involved with the motor if it is running good, respectably.
You might want to attend to any oil leaks first of all. Remove the head, true it up, decarbon, and install a new headgasket. If the points cover is leaking, replace the points pushrod, and install a new gasket. The best way to paint your motor is to remove it from the frame. Always identify your wire leads, and disconnect the battery before wire removal. Once the motor is squeeky clean, you can choose to primer, or layer your choice of color.
OCC is a helpfull place to help you. The time you put into will be the reward you get, so take the time to do the job right the first time. Having paint overspray on parts like wheels, ect. , is not a quality paint job. If you have a sincere desire to see how great these machines are, then you will feel good about your work, and hopefully show us a thing or two!
Good luck, we hope you choose to make it a good and better running tractor!
Tags
cub 122, resto
