Old 11-09-2012, 08:57 PM
Loganvilledude's Avatar
Default The Barn / Shop
While I was cleaning out the barn of the property we recently bought I found these.
16 pieces of 8"x10"x 16' old pine timbers>
I'm not sure what the heck I'm going to do with these, but they sure are nice and heavy! I have had a few friends look at them and one said I should get a band saw and cut them in 1" slabs. I thought about another barn or lean-to, but I really don't know.
Any suggestions of what to do with these and put them to the best of use?
Old 11-09-2012, 10:11 PM
Nice find! I'm sure, you'll find a use for them.
Old 11-09-2012, 11:58 PM
Those are impressive! They would make great support beams for the barn expansion.
Old 11-10-2012, 04:48 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
do your homework on them, if they are old barn timbers , you'll find they are worth some jack.
would also be nice for the start of a 40x80 house for the cubs.
Doug
Original , 100 , 125 , 582
Old 11-11-2012, 12:06 AM
ihcc104's Avatar
ihcc104 ihcc104 is offline
What He Said ^^
Old Wood can be worth a lot if it has the right tight grains and straight. DO some homework, although pine isn't the most desirable because it is a soft wood, they still may be worth some $. Also I wouldn't cut them into slabs, their use is better when they are whole. Plus... There is no way you could really cut something that large on a bandsaw...
- Cory Sanderson
Old 11-11-2012, 01:51 PM
cub149's Avatar
cub149 cub149 is offline
Are they hand hewn or saw mill cut? If hand hewn they are worth some $$ . If they are old growth they are still desirable, people use them as a beam or saw them into tongue and groove flooring. I'd do a little homework on them before using them. You may get enough out of them to triple the wood you have there.
Chip T.
Drexel NC
