Old 11-19-2012, 07:19 PM
brentwd's Avatar
brentwd brentwd is offline
Default ccc/mtd serial num. list
I have been looking for a serial number list for the models from 1982 and on. Does anyone have the list? I would like the entire list for all models.
Old 11-19-2012, 07:58 PM
PM sent to you
Old 11-19-2012, 09:57 PM
brentwd's Avatar
I appreciate the info DWayne. Is this something that would be on the manual list. It sure helps.
Old 11-19-2012, 10:23 PM
I'm not sure. I was lucky enough to have a gentleman send me the lists a couple of years ago.
Old 11-20-2012, 08:06 AM
PaulS's Avatar
PaulS PaulS is offline
I highly recommend a book titled 50 years of Cub Cadet by Oscar H Will III. Not only does it showcase each cub from the original through the 21xx series which by the way came out after the 3000 series. It is a wealth of info including 2 Serial # Listings.
Old 11-21-2012, 12:33 AM
DWayne, ole buddy, ole pal. Could I also use that list.
Thank you sir
Old 11-21-2012, 07:02 AM
Thank you sir
Same here, PLEASE
Old 11-21-2012, 08:06 AM
Better yet, why not add it to the technical library so everybody has access to it.
Old 11-21-2012, 10:44 AM
Thank you sir
Same here, PLEASE
Will get it sent Sam and Todd and yep, I'll see what we can do to post it in the Tech area.
Old 11-21-2012, 05:31 PM
You Da Man! Got it thanks much!
