Old 12-19-2012, 09:15 PM
bluesman bluesman is offline
Question A weighty issue
Started taking my 1450 parts tractor apart today and wow is that front grill shell heavy. I assume that it's cast iron. I noticed that it is quite rough. Is that as cast or is it just from age? I intend to refinish it and don't want to make it smooth if it was originally rough. I once had a 1250 but never had occasion to remove the grill shell so the weight really surprised me. Now I know why these tractors last so long and why the newer ones probably won't
Old 12-19-2012, 11:35 PM
cubby102's Avatar
cubby102 cubby102 is offline
They are cast rough like that. I've seen a couple people smooth them out and didn't like the look of it at all. Takes the old well built iron look away.from it
Old 12-20-2012, 12:26 AM
Well then you should lift one off a narrow frame. To me they feel more heavy. I've got mine off the 125, tomorrow for the heck of it I'll throw it on the scale.
Old 12-20-2012, 07:59 AM
PaulS's Avatar
PaulS PaulS is offline
My son and I just last night removed the grill from a 102. Yes they are very heavy, rough cast, and built to last. The grill is at least half to two thirds as heavy as the engine which we also removed last night.
Old 12-20-2012, 12:37 PM
The early QL had CI lower grills and the later QL went to a alum casting.
Old 12-20-2012, 04:08 PM
TheIHMan's Avatar
TheIHMan TheIHMan is offline
I've seen a person smooth out the casting on a Farmall M and I didn't like the look of it at all. I'd say keep it as it is.
Old 12-20-2012, 04:56 PM
TheSaturnV's Avatar
When I picked up the grill off my 147 it seemed like it had enough metal to form an entire modern rider/mower. Agree on leaving the rough cast look. I did go through mine and clean it up a bit, like removing flash off one of those old plastic model kit parts, but as far as the texture I left it original.
No wonder we love these old tanks so much.
Old 12-20-2012, 06:53 PM
I'll be careful to leave it rough......looks like I'll have to use stripper on it. Yeah, I look at my 2185, built in 94 and it looks like about 1/4 of it is some kind of plastic. Makes me wonder what it will look like when its 40, or if it will even last that long.
Old 12-20-2012, 08:39 PM
I completely forgot about weighing the grill shell, we are getting dumped on with snow, I'll try it tomorrow. Unless I forget again.
Tags
cast iron, grill, weight
