ok guys...i aint very good at converting things. im trying to figure out my lights on my blazer..they are off road lights tht put out 100watts...i need to figure out how to convert watts to amps..i have 5 lights but each will be on a toggle switch and fuse...so any help will be greatful.
Brandon CC models: 86, 100 w/hanban sickle mower & 1872 1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade 1965 100 w/hanban sickle mower 1989CCC 1872 w/50c mower |
man don't you have Google
volts times amps = watts or about 7 amps each |
More like 8.3A each...check your math.
yeah ive got google but i dont have any luck with it. so a 10amp in line fuse will work with a 15amp switch. i can wire a cub no problem but not my own truck
just maken a little joke -Google well they are 100 watts total ? or each ? probably came with a wiring harness right ? I would use a 30A relay comeing off a fusable link or inline fuse and a toggle to trigger for sure
7.1 amps at 14 volts 8.3amps at 12 volts ( not charging ) but if your not charging its going to be more like 10 amps at 9.9 volts soon |
