Old 02-02-2013, 09:33 AM
cfiles cfiles is offline
Default 682 repower
I've got a 682 roller that I've decided on repowering with a ch18s.
The donor is a rusted out 2185.
Several other members have already done this conversion, and made it easier for others to follow your lead. I already know the wiring is gonna be an issue for me, so i'm going to get motor mounted, then tackle that. I was hoping that someone may have a laymans wiring schematic to help me muddle through the swap. I am going to use this tractor for mowing, so I swapped the pto from the KT17. The 682 S/N2050600u743397. And the 2185's S/N 385633. Any help will be greatly appreciated.
Old 02-02-2013, 09:57 AM
Was that the 2185 off of CL in Bham? That was a great deal if you got that one. I'm sure someone will help you out here. Welcome to OCC.
Old 02-02-2013, 10:50 AM
Leadslingingdaddy's Avatar
Get with SamMac for an easy upgrade to that engine to take it into the 20+ HP range
Old 02-02-2013, 11:02 AM
Oak, Yea that's the one. The tin is rusted out and had been sitting couple years, but runs good now.
Old 02-03-2013, 09:04 AM
This is on Flea Bay
http://www.ebay.com/itm/Kohler-24-85...item20b97cd6df
If you want more power out of that CH
Old 02-03-2013, 09:54 AM
Attachment 32664
Attachment 32665
Couldn't you use the wiring harness out of the 2185?
Old 02-03-2013, 09:57 AM
This is on Flea Bay
Looks just like the one I got from my buddy in VA.
Old 02-03-2013, 10:13 AM
It's easier to use the 682 wiring with a couple minor mods, ask me how I know.
Yep it is just a different seller.
Old 02-03-2013, 10:17 AM
This is a list of the parts you will need to do the CH swap. This is what is used on an 1864 and it makes the swap almost a bolt in. Try the sponsors for the parts.
1 603-0025 Plate Assy, Engine Mounting nice to have but you can use the plate you have.
2 736-0185 Flat Wash, .375 x .738 x .063
3 710-3118 Bolt, Patch, 3/8-16 x 1.0 Lg
4 750-3009 SPACER (4) you will need these
5 710-3124 Bolt, Patch, 3/8-16 x 2.25 Lg
6 751-3110 Muffler you will need this
7 711-3006 Stud, 7/16-14 UNC-2A Thd you will need this
8 736-3086 Washer, External Lock, .45 X.75 x .03 Thk
9 703-2176 DUCTING-MUFFLER you will need this
10 736-3024 Washer, Flat, .47 x .750 x .0605 Thk
11 712-3019 Hex Nut, 7/16-14
12 703-2177 Duct, Engine
13 736-0142 Flat Washer, .281 x .50 x .063
14 710-3209 Bolt, Hex, M6-1.0 x 10 MM Lg GR5
15 710-0224 Hex Washer Screw, #10-16 x 0.500
As far as the drive shaft I would cut the shaft from the 2185 and slip it over the existing shaft for your 682 get the length adjusted to whatever it needs to be then drill a ¼” hole through it and put a spirol pin in it, maybe even two just to be safe. That way you don’t have to go out and buy an adapter to bolt the shaft to the back of the engine. The 2000 series drive couplers are pretty bullet proof and they don’t need any maintenance.
