Go Back   Only Cub Cadets > Off Topic > Gardens, Lawns and Landscapes
Old 03-17-2013, 12:07 AM
jacobd jacobd is offline
Default Plowed a garden today.
Had a blast. Used a 10 inch plow behind my 124 with worn 8.5 ags, a set of IH weights, and 5.5 gallons of windshield washer fluid in each tire. Only issue is I could've used a little more weight. It was all I could do to keep the land side tire from slipping but then again as far as I know this had never been plowed so it was tough.
Tried second gear but had trouble with the clutch slipping so I did almost all of it in first. I think the tractor worked me almost as hard as I worked it! Now I see why people like hydraulic lifts.
I may have plowed a bit much but this is the first time I've ever really tried gardening and I figured too much is better then not enough. Plus it was fun
After a few runs I mashed down the pedal, heard a snap, and the next time I went to stop I had no clutch only brake a quick look over found it was just a broken return spring that had allowed the clutch release arm linkage to slip out. Thankful it was an easy fix.
This was the end result. Need to disk it next.
The 10'' brinly plow worked good after I got everything adjusted except the coulter was all but useless. seemed to just flex out of the way rather then cut much. Maybe it's just cause the dirt was hard. I've heard of people cutting notches in them to help with penetration and after watching it on the plow it seems like that would work great. Does anyone have any feedback on doing that? I might try to make up a notched coulter wheel to have in case I need to plow something like this again.
Old 03-17-2013, 01:08 AM
Donovan M.'s Avatar
When i was plowing corn stalks with my 12inch brinly. I took the culter off because it wouldnt let my plow go in the ground deep enough.
Donovan:
62' Original-fenders
Old 03-17-2013, 01:10 AM
Donovan M.'s Avatar
Here is my 12 inch brinly on my cub cadet 100R.
Donovan:
Old 03-17-2013, 06:41 AM
Looks like you were busy!
Nice looking plowed dirt!
Old 03-17-2013, 09:24 AM
CubNub's Avatar
CubNub CubNub is offline
Man you weren't kidding when you said you put that 124 to work. Nice job!
Old 03-17-2013, 09:40 AM
PaulS's Avatar
PaulS PaulS is offline
Good job on the plowing. Can't do that here as about 3 inches of snow fell yesterday.
Old 03-17-2013, 09:57 AM
Great pics, you did a good job!
Old 03-17-2013, 12:25 PM
Love that red Carolina dirt!
Old 03-17-2013, 01:03 PM
That ain't "dirt" - that is unbaked bricks!!
Actually the red comes from iron in the soil, so lots of the red dirt is great garden soil.
BUT, some of it is still unbaked bricks!!
OK, when does the discin' start!!??
We need a video!!
Old 03-17-2013, 02:00 PM
Jumper Jumper is offline
jacobd: Nice Job with the plow! I can't wait to get out there ....... by the way, happy St. Patty's day everybody !!!!!!!!
