Old 04-21-2013, 12:50 PM
koseals's Avatar
koseals koseals is offline
Default Cub Cadet 1330 Drive Problem
I have 2 Cub Cadet 1330's with Hydro Drive problems. One went out last year & the other a couple of days ago. Belts are fine. I pulled them both and opened the trans-axle housings. One has a busted Differential Housing Assembly (Part #717-0777) which is a repair I have had to make before, but the other trans-axle appears to be in good working condition. All the gears, splines, etc... are in good condition. I also pulled the Hydro Pump off the trans-axle and checked the splines between the pump & trans-axle & they also look fine. With the unit reassembled, I can turn the drive belt pulley and engage the forward/reverse lever and the axles do engage & turn. Any suggestions?
Old 04-21-2013, 01:50 PM
Number 12 (red arrow) is a filter, looks like you remove #9 to get at it. Maybe it’s plugged.
Old 04-21-2013, 02:00 PM
koseals's Avatar
Thanks Sam Mac! I will try that!
Old 04-21-2013, 02:37 PM
I want you to understand that I have never worked on this model. I suggest that you get the service manual for it. Here is some more info
http://onlycubcadets.net/forum/showthread.php?t=835
http://cubcadet.custhelp.com/app/ans...ervice-manuals
Models: 805, 1015, 1020, 1105, 1110, 1215, 1220, 1315, 1320, 1330, 1405, 1415, 1420, 1605, 1610, 1620, 1715, 1720
Form # 772-3870
Tags
1330, drive, hydro, transaxle, transmission
