I was givin a Cub 1806 with a pull behind as a new home onwer present from a relative and the thing is a little rough. When I got it last weekend, it only worked in 1st & reverse. This past weekend I was pulling a cart with it, and I slipped/grinded it into 1st. When I put it into neutral to load the cart, 1st & reverse didn't work anymore. Now 2nd & 3rd worked which sucked because i really need reverse. I slipped/grinded into 2nd, put it in neutral, tried 1st, and it worked. Now 1st & reverse are currently working. Does anyone know what is causing this? My first thought is there is a clutch engagement issue, but than again I'm no mechanic. If it helps, the creeper gear will not engage either. Any help would be great
Also, the deck that came with it is shot. It needs more weld than not. If anyone would have one and would be willing to part with it please let me know. I live near Chippewa, Pa. |
![]() ![]() As for the deck, best is to place an want add in the wanted section of the site.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
Sounds like possibly two problems.... Id start with taking the tunnel cover off and see if the driveshaft stops turning when you step on the clutch. If not, see why the clutch isn't disengaging... As far as, why it wouldn't go into first or reverse... You may a detent sticking in the shifter top....... But your description contradicts itself, did it "slide in" or "grind in" ... it really cant do both. It will either be sliding into gear, or it will be grinding into gear....
![]() Quote:
Welcome to OCC! You've came to the right place with your 1806!
