Well I thought most of you guys would like to see this and most will think it is a shame as I do. Where I work they have this Farmall Cub that was at one time converted into a forklift....no big deal right?? WRONG!! The serial number is 502!! If I'm not mistaken they started at 501.
The picture isn't very detailed, but it almost looks like a Farmall BN.
someone correct me if im wrong....but i think IH made some forklifts using cubs back in the day. i thought i remember seeing a few here and there in my travels.
I think they did and john deere did the 420 also ford 2-8-9N, Im sure there were others.
Keep dragg'n em in. They're like orphans...they all need a place to call home. |
Definitely a cub engine and cub hood/fuel tank. I don't know if they ever made anything like that from the factory. Usually special made equipment had different serial number tags or modified stamping to the tag. So it might be a home made deal with cub #2 used.............
Under edit: after looking at the tag again, it appears there's a PP stamped on there as well. Hmmm.........
Josh Diesel Cub Cadets........... |
That's a Farmall Cub. What a shame on such an early one.
PP should stand for powerplant so it was probably the 2nd power plant cub built turned into a forklift.
Adam Current Workhorses: 1977 1650, Sleeve hitch, #2 tiller; 1985 782, QA 42A snowblower, 50'' deck, 42'' blade, Ags, IH Wheel weights; 197? 1250; 1976 1250, hydraulic lift, 44'' deck, 54'' blade (currently needing a engine) Current Projects: 1970 107, Sleeve hitch, 42'' deck, Tri Ribs, 8'' Brinley Plow Family owns over 30 tractors, 7 combines, 2 bulldozers, 2 mid size trucks, 1 semi, too many truck and scouts to count including parts, and 3 pulling tractors. All vintage IH. |
I have driven a fork lift that was a farmall cub.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10:
IH Made a lot of fork lifts out of tractors using a "reverse operation kit" I have a 47 Farmall Cub serial number 529, you are correct the beginning serial number is 501.
Rob GT's: 1972 IHCC 129, 1984 CCC 782 LT: 1991 MTD/CC 1415 with bagger Farmall Tractors: 1947 Cub (I'm 2nd ower, 99% original with paperwork), 1946 H, 1951 M w/ SM kit, 1955 300 row crop. *Sold Tractors*: 1941 AV, 1944 BN, 1947 BN
Yeah, but if it wasn't a forklift it would probably have made it into a scrapyard by now.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
