Old 05-01-2013, 11:06 PM
ftummine ftummine is offline
Default 1440 wont start
replaced starter and solenoid.
jumped solenoid and starter motor turns
when i turn just the key solenoid doesnt click.
im learning on the job here, not much past experience with this stuff
any help would be appreciated
Old 05-01-2013, 11:07 PM
Welcome to OCC! You're at the right place for your cub troubles.
Old 05-02-2013, 03:39 AM
cubby102's Avatar
cubby102 cubby102 is offline
Sounds like a bad ignition switch to me. Welcome to the site
Old 05-02-2013, 06:10 AM
Old 05-02-2013, 06:22 AM
So, to clarify, is your complaint that your 1440 won't start or that the engine starter does not roll over...???
Old 05-02-2013, 06:58 AM
Well it turned when i jump starter and solenoid.....didnt try to get it running.....
Old 05-02-2013, 08:24 AM
cubs-n-bxrs's Avatar
Sounds like a malfunctioning safety switch or bad ingnition switch. Possibly bad connection at ignition switch.
Old 05-02-2013, 08:41 AM
Time to break out the multi-meter and check what Kelly said.
Old 05-02-2013, 09:13 AM
Here is a sequential Wiring Diagram for the Starting Circuit for the 1440
The Ignition switch only makes contacts (B to S) in the Start Position
The Brake Switch only makes contact when the Pedal is depressed
The PTO Switch only makes contact (C to D) in the OFF Position.
Obviously, you have to have a good fuse.
